Hello,
I am interested in using a post hole auger with my WD. I have an after market 3 point hitch on the tractor that I also have attached to a Cat 1 quick hitch. I think I probably have to remove the quick hitch. The bigger problems are the top link then as well as the tractor step above the PTO being in the way of the PTO shaft when it raises. Have any of you guys successfully used a post hole auger with a WD? If so, what were your solutions to those problems? Thank you in advance.
Rifman
Rifman
