Allis Chalmers Discussion Forum |
Allis Chalmers D-17 Throttle/Governor
Author |
[Modern View] |
aaronknodel
02-12-2021 13:52:05
Hi all, so after a governor weight came free and chewed up the timing gears I've got my D-17 back together and running, but the throttle is all out of whack. It idles way too fast almost close to wide open, and the throttle lever has only about half an inch of movement to wide open. It looks like the linkage is hardly moving after the governor so it seems like the problem is in there, anything I should be looking for when I take it apart again? Thanks
DrAllis
02-18-2021 16:23:40
Re: Allis Chalmers D-17 Throttle/Governor in reply to aaronknodel, 02-12-2021 13:52:05
Shorten (bend) the link rod like I said to do and try it !!! 1/4" too long makes a HUGE difference how the governor works.
aaronknodel
02-18-2021 13:07:41
Thanks for the quick response! So I can confirm that the governor assembly sliding sleeve is put in correctly. To your second point the vertical arm does move forward against spring pressure about and inch and spring back. To your third point, when I remove the carb link the vertical arm does move back a little, (towards the rear of the tractor). However I'm not sure that the carb link is the issue, I am thinking it may be the horizontal shaft in the timing case. The reason I think this is when the vertical arm is free from the carb link I can see the little forked piece (which makes contact with the thrust bearing on the governor shaft) move back and forth when I move the hand throttle up and down, however when I re-attach the carb link and the vertical arm, this forked piece barely moves a quarter inch, am I correct in assuming this shouldn't be the case? It's clearly not engaging the way it should be.
DrAllis
02-12-2021 15:48:50
Are you absolutely sure you have the sliding sleeve on the governor assembly installed correctly?? The ball bearing goes towards the radiator. The largest diameter goes towards the rear. Until you KNOW that this correct, nothing else matters at this point. With the engine OFF and hand throttle half-way down, you should be able to grab the vertical governor arm behind the generator and move it forward (against spring force) and let go of it and it should spring backwards. Total movement is just an inch or so. If this is free to move, then the next step is synchronizing the governor to the carburetor. Leave the hand throttle half-open. Remove the cotter pin at the top of the vertical governor arm. Pull out the carb link rod. The governor arm should not move rearwards one bit. If it does move rearward, bend the link rod down in the middle to shorten it. Make it so it will just slide back into the arm hole. Now, when you place the hand throttle clear UP, the carb throttle shaft should be clear shut against the adjustable idle speed screw, so the engine will idle. If this is OK, fire it up and see what you've got.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important
... [Read Article]
Latest Ad:
1967 Ford 3000
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
