Company Logo Shop Now
Re: 1954 WD45 how do I adjust the clutch and to wh
tracker1961
02-06-2021 18:15:50
Thanks for the reply. I do believe the seal is leaking between the Hydraulics and transmission. Fluid comes out of my fuller plugs on both transmission and rear end. I dont believe hydraulic fluid will hurt anything??
The adjustment is needed on my engine clutch. Ill look tomorrow for a way to adjust the clutch pedal. I have only looked at the clutch shaft for adjustment there. And there is none on that clutch shaft. Any adjustment on the clutch itself? Ill open the inspection plate tomorrow, and look for spring parts etc.
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
