Allis Chalmers Discussion Forum |
Got the clutch working.
Author |
[Modern View] |
bwillett
02-06-2021 03:18:05
Pulled the engine after some discussion with my mechanic friend. Ground the edge of the pressure plate so it would slide into the flywheel with out binding, reinstalled the pressure plate and the fingers looked better, as in they were farther away from the clutch surface than when we started. Checked everything in the bell housing for correct fit and alignment. pulled the clutch release bearing carrier to see why it was binding. The clip that holds the carrier and the forks together was too tight on the fork and would not let it work. Changed the clip out for the old one and it worked......Put the engine back in and could not get the bellhousing within 1/4 inch of the back of the engine. Looked at the clutch and the fingers of the pressure plate were holding it out. Ran them in and bolted up the engine to the bell housing, re-adjusted the fingers to the proper gap, and it is all good... Now to get the rest of the tractor back together...... Back on it Monday.
bwillett
02-06-2021 03:27:14
Re: Got the clutch working. in reply to bwillett, 02-06-2021 03:18:05
And, before I forget, I want to thank mswartz, rrLund, Old, ramblineagle, Aaron SEIA, charlesleddy, Ifnel, Cheesehead Fred, and 4wdTom, for your help, and suggestions, you guys helped me to look at the problem from a couple of different angles.......Be ready, for I will probably have more questions before this is all over.....
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance."
... [Read Article]
Latest Ad:
Single front for Int M, 706
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
