Company Logo Shop Now
Reinforcing loader on D17
Jhncp
01-14-2021 06:16:58
I used my D17 to lift a disk I bought and it pick up the earth with it (6" frost). It also lefted up an entire John Deere 24T baler with kicker that had no wheels so I could back my trailer under it. The only issue I have is the support brackets on loader are giving out. I'm thinking I will need to make a bracket to go over the hood and then run some uprights to it from engine tractor frame bolts or?
Alvin 41
01-14-2021 17:47:12
 Re: Reinforcing loader on D17 in reply to Jhncp, 01-14-2021 06:16:58
I had a Miller Quick -Attach Loader on a D-17 that had a frame around the tractor front that it rested on and was the ground foot when dismounted . It had 2 way lift cylinders and lifting a complete combine grain head onto a truck at full extension both cylinder rods bent. They were too small diameter for the piston .
DrAllis
01-14-2021 15:46:10
Over the top is fine, but there should also be one down near the bottom of the towers if there isn't one there already.
Brian G. NY
01-14-2021 09:15:14
I wonder what model loader you have. Both the A-C model 400 and 500 loaders are set up like you propose to do. Looks easy to duplicate.
Jhncp
01-14-2021 09:28:41
 Re: Reinforcing loader on D17 in reply to Brian G. NY, 01-14-2021 09:15:14
Allis Chalmers 170 made by freeman
Jim.ME
01-14-2021 08:18:58
Reinforce them and see what bends next. Unless there is obvious deterioration of the supports it could be a sign of overloading. Just because it can lift something doesn't mean it should. JMHO
Jhncp
01-14-2021 16:20:48
 Re: Reinforcing loader on D17 in reply to Jim.ME, 01-14-2021 08:18:58
Today's Featured Article - ... [Read Article]
Latest Ad: Single front wheel assembly for 18-27 hart par [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
Binary file (standard input) matches
