Starter for 262 diesel
hey everyone, hope all is well and safe. curious if anyone has a starter or parts specifically armature, and nose cone with 3 bolts for a series IV d17 diesel. thanks. my armature shaft broke because nose cone was worn, disasters.
I put a reduction drive starter on my D17
from a 6060 6080. Just googled it. But I
have a original starter for a 262. Located
in SE Illinois.
https://www.amazon.ca/DB-Electrical-SNK0009-Starter-Chalmers/dp/B0081SBVGU/ref=asc_df_B0081SBVGU/?tag=googleshopc0c-20&linkCode=df0&hvadid=459436180742&hvpos=&hvnetw=g&hvrand=7086262510120134494&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1002287&hvtargid=pla-569866456281&psc=1
if you go down it shows a part number Allis Chalmers 4917197
that 491 number typed into wilson auto comes up with that starter link below
https://www.wilsonautoelectric.com/Search/GetPartSearchType
i cant find what the 491 tractor is. is the 6080 6060 the same three bolt pattern??
It's been a while. But might have had to
drill one hole. But little gear drive
starter sure spins my D17 it has 604 cu.
21.5 compression.
(quoted from post at 20:33:46 11/12/20) It's been a while. But might have had to
21.5 compression.
how much would you want for the starter??
wow, the world needs more people like you. and me to live closer to them lol. ok let me see what i can do. why did you change starters?? because the 262 is such a pig to turn over lol.
I'm pretty sure they are the same almost.
I looked and had to grind the inside hole
out. It is bigger on the old starter.
My motor is so hard to turn now the older
starters just aren't powerful enough. I
have 2 big.batteries also. Also the
reduction starters are a lot lighter. It's
on a pulling tractor. I'll look for my
old starter. Tomorrow
wow those look fun. yeah i can agree 100 percent on these motors are pigs to turn over. i have an electric golf cart with 12 v batteries i can start it with one but it needs to be absolutley fully charge or else i need to use two of them. goes with all other diesels i guess, batteries are everything when it comes to starting.
when you say had to grind the hole out bigger, are you meaning on the housing the starter bolts to the tractor or the 6060 starter itself?
I found it finally. But the nose cone
inside bolt hole has been welded on. Must
have cracked. But. Vic Simpson . 2145 Co.
Rd. 50 N. Barnhill Il. 62809 USA.
no rush at all. appreciate it. i will get a long distance package and give you a call. think it will be easier than bounicng info back and forth like this or if you have long distance i can give you my number.
HEY SORRY FOR THE LATE REPLY whoops, i didnt see the second page, (amatuer), the starter looks different than mine. my nose cone can be fixed just needs new bushing, bigger one. so not to worried. i need the armature. is really the main part i need, spesifically the shaft. 905-746-7057 daniel
