Al L. in Wisc.
Second owner of 1955 wide-front CA. Had it sitting in garage ~ 6 years; water in sediment bowl lead to dropping bowl; replaced; lead to replacing radiator hoses, lead to install new temp gauge, lead to getting new light-charging switch; dropped it and broke it internally; lead to ordering new switch and misplacing it; lead to other priorities I.e. life STUPH, etc. Found switch. Gonna get back at it. ? is are pistons flat on top as I'm gonna shoot some Sea-Foam in cylinders with needle as plug holes are so horizontal. Want to make sure I have adequate amount in for cylinder soaking before I would attempt to fire it up. Have had rear on blocks so will soak for a few days and turn rear wheel. One ounce enough or a larger quantity? "Ran when parked" Yup, it really did. No smoke; smooth quiet runner. Spent it's working days hauling manure and tobacco field work. Thanks in advance for any input.
