Re: How to tell series ll
Skyhighballoon(MO)
11-02-2020 07:49:16
Aaron I assume by your statement you meant to say "...it got the WD engine STYLE low pressure bypass filtration." Every D17 had the G226 engine with larger journals and the center thrust bearing. No W226 engines were used in D17's.
That picture of the chart is also wrong in that all Series I and II did not have power steering pump driven off the back of the generator. I'm not sure of the SN break but somewhere along the way it changed to being driven off the back of the governor housing (between the governor & distributor) before it moved to left side belt driven in Series III. I have a very late Series II parts tractor that has the governor driven power steering pump, hood panels w/o the metal name tags and the updated wide front end wishbone (that was effective SN 38136).
