Snap coupler blade
Picked up this snap coupler blade at an auction, it looks different than other AC blades I have seen. What do I have? There was a C and a styled WC and a Wd45 on the sale so he musta used it with 1 of those.
It looks like some kind of home made converted 3 pt blade. I wonder why the loop is 90 off? Looks like you need to flip it end for end to get the right loop.
AaronSEIA
First off, it isn't an Allis-Chalmers brand blade. It appears to be a Brand XY or Z that could be 3 point or snap-coupler, except the eye for the snap coupler hook is vertical.
I don't know if it is AC or not. However the vertical eye looks rough like it might have been torch cut and welded on to the end of the proper snap coupler eye which can
be seen on the other end. It's hard to see but that seems like a possibility. AC could have made things for snap couple and 3 point as some tractors could be had with
either.
Yes thats what I cant figure out, the eye is wrong direction its in the vertical position. The eye that is pointing out now has been welded onto the original style eye that is in the back position.
The only thing I can think of for the vertical eye and this strictly a guess is that the WD45 you speak of does not have a snap coupler and this blade attached to the draw bar pin. That eye however would be a very sloppy fit on a 1" pin.
(quoted from post at 19:21:48 11/01/20) The only thing I can think of for the vertical eye and this strictly a guess is that the WD45 you speak of does not have a snap coupler and this blade attached to the draw bar pin. That eye however would be a very sloppy fit on a 1" pin.
Yes I think this is how it was used, there is a bushing in there I took out for a 1 hole. Thanks for help guys!
My guess is the C at the auction had a plow lift kit on it. The front eye is sideways because that is how a C plow is. The lift arms look like the width of a
plow lift also.
