Carl Wentzel
New User
I have a 1954, Allis Chalmers WD45 Tractor with an Ensign KGn1 dual fuel (LPG and gasoline) fuel system (photo below) that I am restoring. The tractor runs great on the LPG system, however, the gasoline system has not worked in many years. The gasoline fuel bowl on the gasoline carburetor must be replaced.
The fuel bowl has corroded away where the housing that the Strainer Cage or casting (bulbus cast brass housing is connected to the float bowl by the brass Strainer Casting Nut (photo below).
Does anyone have a float bowl for an Ensign KGn1 carburetor? Does anyone know where I should look for one? Does anyone have an Ensign KGn1 carburetor that I could buy?
I also have included a photo (third Photo below) of the left side of the tractor to show some of the progress I have made so far in the restoration process.
I would appreciate any help you can offer with getting a float bowl for my tractor or an Ensign dual fuel carburetor for my tractor.
Thank You,
Carl
Thank You,
Carl
