Will it work to turn rear wheels around on wc?
jhncp
The way it is it's dished out and offset wide on rims as well. It looks close and hard to tell if it will work or tired will hit fenders or rim hit drum. I know I could unbolt from rim to adjust but that would be more work.
When I put the culavator on I turned them around the tire tread is backwards when you do this. That was fine for cultivating they were getting changed back the next day. You'll have to switch side to side to keep the tread in the right direction.
