What all sizes of tires will fit a WD. rear?
I think that is what I have on my WD45 and will work just fine on your WD. If your just replacing one tire I'd stay with the 13.6X28 so as to match the other side
WD's early on usually had 11.2 x 28's or 12.4 x 28's on a 10 inch wide rim. A 13.6 x 28 was seen on later models of WD's as an option. WD-45's were standard equipment with 13.6 x 28 and optional 14.9 x 28's on a 12 inch wide wheel. Ideally, you want to keep the same diameter/height as your other tire regardless of the actual size listed.
Whatever you do, use the right size rim for the tire. If you're just replacing the one side stay with same size. You should have 12" wide (inside bead to bead) rims now if 13.6 tires.
I seen one with Gleaner "E" tires on it. They are something like 18 x 24". I was thinking about doing that but could not bring myself to actually do it.TOO BIG cleddy
