WD loader trip to hydraulic
Quinnford
New User
Hi I have a wd with front loader and it has a trip bucket. I was given a loader off of and Oliver 550 that has hydraulic tilt. Is it possible to pull off the hydraulic cylinder ,controls ,brackets etc and mount them to mine turn it into a tilt instead of trip? I do not know much about hydraulics so any help would be greatly appreciated. Oliver loader has external controls two levers, lines the ram and mounting bracket. Mounting isn't an issue I'll weld something up and make it work I just don't know how I would connect into the pump.
It will work, but very slow. The WD hyd pump is only 4 GPM, where the Oliver I'd guess is 8 GPM or more. The WD pump is set at 3000+ psi, so the Oliver valve should have a relief valve built into it reducing that to 2,000 psi, so that is good. Slow speed will be your issue.
Had a live pump on my WD. Don't remember if it was a Char Lynn or M&W. Fits on the back side of the
governor, then put the distributer on rear of pump..
Willie
Here are some pictures of what I did on a
Farmall m to use tilt bucket using just the
original belly pump. I added a factory
double acting add on valve as well as
another splitter block. It was pretty
complicated and hard to figure out.
