D14 Brake Pedal Tight
Have a 59 I believe, D14 left brake pedal is tight. The brake is okay disconnected rod from pedal linkage and pedal is tight. Is there any grease or oil points for the pedal shaft etc?
(quoted from post at 16:27:36 08/28/20) Have a 59 I believe, D14 left brake pedal is tight. The brake is okay disconnected rod from pedal linkage and pedal is tight. Is there any grease or oil points for the pedal shaft etc?
There are no grease zerks on the brake pedals. If the tractor has sat around a lot and outside un-shedded a lot, things could get tight where they go thru the cross shaft under the platforms. Disconnect BOTH brake rods and using your favorite penetrating oil, work the pedals back and forth and overstroke them and take a hammer and tap them side to side. They will eventually come around. You might remove the cotter key and work the right pedal off of the shaft and oil it well and reassemble.
