Company Logo Shop Now
Crack in IB torque tube bell housing
James b
09-06-2020 15:01:13
During disassembly and cleaning the grease out of the bell housing, I discovered this hairline crack. See the picture below. My question is should I try to get that repaired by taking it to a welding shop to weld cast or at least get it braised? I know cast is questionable in welding. Or should I leave it? How much weight would be in that area where the front axle support pivets? Seeing how IB torque tubes are hard to come by, I don't want to mess this up, but want to do it right. Any suggestions and guidance will be a great help. Thank you, Jim
derwen1959
09-08-2020 07:53:34
 Re: Crack in IB torque tube bell housing in reply to James b, 09-06-2020 15:01:13
I remember watching on utube a while ago how almost any cracked casting can be repaired with locknstitch overlapping pins
DrAllis
09-08-2020 06:22:03
How about just leave it alone ?? I'm not there looking at it to get a 100% 3-D view, but what are the odds of this tractor ever being used like it might have been 50 years ago ?? Pretty small I'd guess.....
James b
09-13-2020 16:54:24
 Re: Crack in IB torque tube bell housing in reply to DrAllis, 09-08-2020 06:22:03
Thought about it but I have a snow plow that mounts on the front of the channel frame.
James b
09-06-2020 15:02:54
Below is a closer look at the the crack. Thanks again
old
09-06-2020 15:07:50
 Re: Crack in IB torque tube bell housing in reply to James b, 09-06-2020 15:02:54
A good machine/welding shop should be able to do that and have it hold just fine but thy have to be able to heat it up and then let it cool slowly. Years ago I had a machine shop fix the pressure plate on a Case SC I had that had broken fingers and last I heard it is still holding and that was over 10 years ago. I looked all over for a new or rebuild or even used one and NO ONE had them
james b
09-08-2020 05:44:31
 Re: Crack in IB torque tube bell housing in reply to old, 09-06-2020 15:07:50
Thanks Old for the response, I am most concerned on how the torque tube is circular and when welding it would heat up and put stress on another area and crack.
old
09-08-2020 08:22:43
 Re: Crack in IB torque tube bell housing in reply to james b, 09-08-2020 05:44:31
That is why I say a good shop. A good shop will have an oven to put it in heat it up then pull it out weld it and then back in the oven to slow cool
Copyright © 1997-2020 Yesterday's Tractor Co.
