D17 Oil Fill
Take the right hand hood off and the oil fill will stick out like a sore thumb about center of the valve cover
(quoted from post at 12:30:50 09/02/20) Take the right hand hood off and the oil fill will stick out like a sore thumb about center of the valve cover
Thanks for the quick reply. What oil goes where the black oil breather is on the lower half, right side of the tractor?
Probably if you can find an operators manual for it but good luck on that most likely only way to find one is if some one other there will sell one they have. If you have power steering the fill point for it is behind the grill and you unscrew the little piece that sticks up about 3 inches. I use UFT for the power steering also
Then, there is the dipstick to the left of the gearshift towards the instrument panel that takes a 7/8" wrench to loosen up. This is the one nobody ever checks or changes the 2 1/2 gallons of oil for the hand clutch and PTO gears. Takes Universal Hydraulic/transmission oil.
What fluid goes here? UTF?
