WD 45 hand clutch
The hand clutch shares the oil with the trans and and rear end, Where do you drain the hand clutch chamber when changing the oil in that system? The trans and rear end have obvious plugs to drain them. Does the hand clutch drain on the front end of the PTO shaft where it hangs down?
Thanks for the help.
There are 3 drains. Under the differential, under the transmission over the snap couple mechanism, and the PTO.
