Company Logo (800) 853-2651 Shop Now
AC-190
banjoman09
08-14-2020 16:52:14
I have the FO but where is no 1 on cap please? I had somewires off.....thanks
DrAllis
08-15-2020 20:04:20
 Re: AC-190 in reply to banjoman09, 08-14-2020 16:52:14
Quoting Removed, click Modern View to see Firing order is 1-5-3-6-2-4. I agree #1 is usually kind of close to the front so wires aren't crossing over the top of each other. That engine is an Allis-Chalmers 2000 series 265 and 301 cubic inches, not a 230 or 262 BUDA.
Jim.ME
08-15-2020 19:18:35
If only some wires were off and you know the firing order you should be able to put the rest back working from the ones that stayed in place.
Bob Bancroft
08-15-2020 14:15:36
On the four cylinder AC's with a distributor, number one started out typically being the post closest to number one. But on that Buda based six, I haven't a clue.
Jim.ME
08-14-2020 18:36:34
I would pull the coil wire, remove # 1 plug, put a finger over the plug hole, bump the engine over with the starter (make sure the tractor is in neutral) until I felt the compression coming up, then look at where the rotor is pointing. With compression coming up in# 1 cylinder the rotor will be approaching the post for the # 1 wire. I would do this as often distributor get pulled and reinstalled over the years, often they get turned during the process so # 1 may not be where it was when it left the factory, or a manual shows.
Latest Ad: Wanted 13x28 power adjust rim for D 17 allis in NE Nebraska [More Ads]
