Company Logo Shop Now
Re: Wild running wd
DrAllis
08-13-2020 07:31:37
So, being as how you are a novice at this, let's be certain the governor has or hasn't exploded and go from there. Remove the distributer cap and wires and set them off to the side. Rotate the engine with hand crank or by pulling gently on fan blades to make the rotor tap point straight out 90 degrees to the engine. with your finger, push the rotor tab forward to be sure there is no slack in the gears. Mark where the rotor is now located EXACTLY with a white marking pen or a piece of tape, whatever on the plastic plate under the rotor. After disconnecting the key switch wire from the coil, remove the three bolts or nuts that hold the governor assembly to the engine. Pull the governor assembly out and inspect the weights for damage. DO NOT ROTATE THE ENGINE !!!! Report back as to what you see.
Handcrank
08-15-2020 08:36:08
 Re: Wild running wd in reply to DrAllis, 08-13-2020 07:31:37
Hello, I will follow your instructions and get back to you as soon as I can. Dealing with some health problems at this time. Thank you so much for your help, Don.
Copyright © 1997-2020 Yesterday's Tractor Co.
