Well after several hours of 90 degree temps and sticky humidity i got the AC 5040 loaded and got it home, pictures are below. This is before i washed and cleaned it up, we put a good battery in it and tried to start the tractor but so far no luck on getting it to run. i drained the fuel tank and I pulled the fuel filters off today and they are brand new so i wiped off the glass bowls and put everything back together, it got dark on me. Tomorrow i plan on bleeding the lines and hopefully it will start and run!!
It does have the 9 speed transmission, lift does not leak down, seems to be a nice tractor.
