WD 45 transmission
I am putting the main shaft back together after replacing the double bearing. The manual mentions pins in the collars the gears ride on. There were no pins when I took it apart, what is purpose of them, and where can I get them? How big are they?
Thanks for the help,
Mike
Each of the three "bushings" the top shaft gears ride on must have a pin in them to keep the bushing from spinning on the mainshaft. 70225948 is the part number from an AGCO dealership. Use grease to hold them in place when assembling.
Thanks a lot guys I think I found one during disassembly, I thought it was part of the bearing that came apart. I need 4 right?
(quoted from post at 15:11:37 08/09/20) Each of the three "bushings" the top shaft gears ride on must have a pin in them to keep the bushing from spinning on the mainshaft. 70225948 is the part number from an AGCO dealership. Use grease to hold them in place when assembling.
Thanks again. They came in todays mail
