Wanted front hyd pump off of a AC 6060 or 6080
You said your current pump has a 7/8" keyed driven shaft. You are trying to avoid getting a new 1" shaft because you don't want to bore out the coupling half to 1". Looking in parts books it doesn't appear any of the 6000 series hard parts are directly interchangeable with the 615 pump parts. How is a pump from a 6000 series, which also has a splined driven shaft as Dr Allis posted, going to help you?
If your hydraulic guy can get all the other parts your pump needs, it would seem quicker and easier to go with the 1" shaft and bore the coupling, to keep your current pump. You will know what you have and that it fits, rather than dealing with another used pump that may have issues and fit up differently. JMHO
Im not sure what you were referring to but my Webster dealer said my pump someone aluminum welded one of the sections and then tried
machining it and it had air bubbles in the weld and machine surfaces did not fit perfect causing a small drip
and the gear set really should be replaced also and the surface on the 7'8 shaft wear the front seal fits had pits. he said he has the
seal kit in stock and it searching for whatever parts he can. . so yes I would rather buy a good used pump which is probably going to
have a 1" splined drive and the change the pump 1/2 of the drive to whatever it is, probably splined. Whoever I get the pump from should
be able to also give me the 1/2 coupler that came with the pump also_Other wise someone did say that there were some Case 580D,s that came
with a Webster pump with a dual pump. so Im looking at that possibility too. and the other alternative is a single pump that has the
lower of the 2 attachments pressure , which is the backhoe around 8.5 gpm I was told and then just use a single pump , and tee a
pressure relief in the pressure line leaving the pump back to supply tank and use a manual priority valve mounted in operators station to
go back and forth to use backhoe and loader.
(quoted from post at 10:23:24 08/02/20) Im not sure what you were referring to but my Webster dealer said my pump someone aluminum welded one of the sections and then tried
Ok. The 6000 pumps I was looking use a splined gear drive adapter off the engine, not coupled to a shaft driven from the crank like yours.
Maine Tractor Crossing's website shows a used pump for a 6060 AC. You could check that one out if you want. He may or may not still have it.
thanks Im going to call them it looks alot like what I have , different drive and fittings are 90 degrees but mine should work in it.
the GPM is a little different but I would think that is ok.
So if its not coupled to a shaft then how is it driven? and how would it be mounted and driven? it has to be mounted to the front of the bolster unless it somehow is bolted behind the bolster and with brackets directly bolted to the crank pulley?
(quoted from post at 08:50:11 08/06/20) So if its not coupled to a shaft then how is it driven? and how would it be mounted and driven? it has to be mounted to the front of the bolster unless it somehow is bolted behind the bolster and with brackets directly bolted to the crank pulley?
A pump doesn't have to be mounted to the front bolster and driven from the crank pulley. Like some others, the 6000 series pump is engine driven off the timing gear train and engine mounted, not like your 615 pump drive and mounting arrangement, that's why it is different than your pump.
Picture borrowed from the internet.
