Company Logo Shop Now
D-14 starting problem
Naber
07-25-2020 13:35:56
I am having a problem starting my D-14. About a year ago I replaced the plugs, points, cap, wires, points, coil, etc. It has been starting poorly but I got by until this summer when I have been coasting it downhill to start it. Then it started missing. Now it won't start at all. It appears that I have a poor spark when I take a plug out and a poor spark at the coil wire. I'm thinking my problem might be electrical. When I looked in the operators manual I realized it's suppose to have a positive ground and I have had a negative ground. I'm wondering if using a negative ground has screwed up something electrical.
I'd like to try a couple other things to get it running before I haul it to a real mechanic . Any thoughts or suggestions would be appreciated.
rustred
07-26-2020 08:08:06
 Re: D-14 starting problem in reply to Naber, 07-25-2020 13:35:56
check the coil wires. on negative ground the - on coil goes to distributor. On positive ground the + on coil goes to distributor. nothing will screw up other than could be hard starting. makes absolutly no difference what ground is used when electrical is wired correctly. if that dont fix it try another coil.
Naber
07-25-2020 13:58:04
[quote="CVPost-old"](reply to post at 21:53:18 07/25/20) [/quote It's a 6 volt with a generator.
I'll check the points again.
Thanks!!
old
07-25-2020 14:24:23
 Re: D-14 starting problem in reply to Naber, 07-25-2020 13:58:04
6 volts and a generator then yes it should be + ground and that will help the spark a little bit since hooked up backward makes the spark just backwards across the plugs
old
07-25-2020 13:53:18
Generator or alternator 6 or 12 volts??
Dirty points or points that are not gaped correctly will cause that
Latest Ad: Looking for a gearbox casing that mounts to a Clinton Machine Company motor Model B764COC Serial# 2070576 part# 3801-C. It powered a Bolen 2 wheel walk behind tractor late 1940s model. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
