Allis Chalmers wc with wide front
jhncp
Is this a factory wide front made by Allis Chalmers or did someone else make it? They removed steering shaft from front gear box and rerouted it to another gear box. As long as I'm at it what's it worth?
I had a picture of an Oliver 70 with a front end similar to that. I've searched my files and can't find it. I posted it either on the Oliver forum or Talk at the time and seems like somebody was able to identify it. Maybe if you searched Oliver 70 wide front long enough on here you might find it.
I'm betting on "homebuilt". Certainly not A-C......I've never seen any WFE conversion that used it's own separate steering box before.
Here we go, I found it. This one straps to the front pedestal too. Pretty sure it's a factory built conversion.
