Allis chalmers b identifying
6 volt starter work just fine on 12 volts unless you hold the start button to long and then it is your bad not the starters bad
Check with this site and buy one of there. I have 4 A/C C tractors and the 2 that run both are 12 volts but both have 6 volt starters and have for decades. Shoot most of my tractors have 6 volt starters n them but wired for 12 volts. Only one that, that is not true on is my IH584 which came from the factory as a 12 volt system
1948 B serial numbers started with 80056 and 1949 started with 92295, according to the serial number list on this site. 89346 falls between them so yours would be a 1948.
