Company Logo (800) 853-2651 Shop Now
1956 WD45 stuck
Gtidwell
07-09-2020 17:46:23
I just got the tractor. It is stuck in third gear. Does anyone know a quick fix? Or is it probably because the shift forks are worn and need replaced. I have not took cover off and checked it yet.
Gtidwell
07-10-2020 06:01:39
 Re: 1956 WD45 stuck in reply to Gtidwell, 07-09-2020 17:46:23
Thanks to everyone. Once I get time to work on it I will post that it is back up and going.
4wdtom
07-10-2020 05:02:22
If you get things lined up and the shift lever back in and you haven't fixed the wear it may/will happen again. However you can probably put off the repair for a good while if you are careful shifting. Move the lever in a distinct front to back, right to left pattern. Don't try and pull/push it at an angle across the shift pattern say from first to fourth as this gives the end of the lever the perfect opportunity to get out of position. Instead, for the first to fourth shift first pull the lever straight back to neutral half way between first and second, then directly to the right over the fourth position, then straight back into fourth. Shifting this way will reduce wear anyway and keep your problem from happening.
Aaron SEIA
07-10-2020 03:29:25
Pull the shift boot up, remove the snap ring and pull the shift lever straight up. Be careful, there should be a square headed pin in there you don't want to lose. Use a long screwdriver and pop the forks back into alignment. Reinstall the lever.
AaronSEIA
rustred
07-09-2020 18:46:46
well take the shifter out and align the rails and ur good to go. 15 minute job.
Gtidwell
07-09-2020 19:24:36
 Re: 1956 WD45 stuck in reply to rustred, 07-09-2020 18:46:46
Thank you sir. I read on a past post, after I posted this to not lift up on the shifter either.
Janicholson
07-10-2020 03:58:58
 Re: 1956 WD45 stuck in reply to Gtidwell, 07-09-2020 19:24:36
The long handle on a WC/WD series can wear the tip of the lever where it contacts the rails. (happens on Letter series IH also) Wear can be welded up and ground/filed back to like new. If there is wear on the pivot pin, that can have a similar remedy. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: good hydraulic unit for JD 50/520/530 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
