AC 200 Hyd hose connections. I must be doing it wrong.
LeakyBoot
200 with the factory remote connectors. Was watching a 1970's youtube from the Allis
Chalmers company advertising the 220. It had the same coupler system and the guy just
stuck the hose nipple in and pushed and it hooked up. I have tried that but maybe
did not push hard enough? I always have all pressure relieved when I tried. I have
been reaching in best I can and pulling out on the hose back of the coupler to get
mine to hookup. It can not be set to work that way as reaching in back is not very
easy. Thanks
Engine OFF. Both remote levers in FLOAT. You'll have to grab the coupler body and pull it rearwards to open up the coupler so you can then plug in the hose. It was a poor design. Later models had levers for each coupler to pull on which would then pull the couplers out for easy connection.
sometimes the sleeves get STUCK or dont move fully...Get some WD 40 or soemthing and spray the coupling on the tractor... forget the other hose right now... work the coupling in and out and make sure everything works and is clean.. full stroke... Then get the hose and try to install.
