Zenith 7078C Carb Float from 38' WC question
This is the first time I have encountered a cracked float on a 1938 WC I am restoring. My question is, "Can I use JB Weld to fix the issue?" I know if I apply too much you change the weight of the float and that is bad. If not JB weld, is there a different product. Normally I would replace, but I am having no luck in finding the correct replacement for this model carburetor, a Zenith 7078C U 3195. Thank you in advance.
