Help with CA head gasket
thdrduck
Trying not to be a pain... going down to help my son replace the head gasket on his little CA (he's not a mechanic but tries). I don't have an IT or shop manual so was wondering if someone could help out with head bolt torque value and valve adjusting numbers. Thanks.
My manual is for a B or C and it says 60 ft. lbs.which is pretty much the same engine Others have posted 60 ft.lbs. for a CA. Use criss cross pattern.
Thanks a bunch guys for the help and Jim, you are an angel. Will send the file to the kid so he will have it. Once again, thanks.
