I was recently given an Allis Chalmers WD from my father in law. I noticed some oil dripping out from the PTO seal when I first got it, and then after running the belly mower it really leaks. Upon dropping the
PTO housing, I noticed some broken teeth on the main gear in the housing. I'm guessing this came from someone trying to engage the PTO before everything had stopped spinning. I'm wondering if this is going to
be detrimental and need to be replaced, or if I can file down the sharp edges on the gear, replace seals, and reassemble.
Thanks
Thanks
