Mike in Ohio
4 quick questions for you guys.
How thick are new brake shoe linings? I have it apart right now and am debating replacing the linings. I measured .130 depth to the rivet. Approximately .210 total thickness.
I can't find a diff cover gasket anywhere on line, there wasn't one there when I took it apart. What is the best sealant to use here? Or should I make a gasket?
What do you guys use for trans/diff oil? Manual calls for SAE 80. Is 80-W90 ok?
The trans output shaft bearings were toast. When I put the shaft back in how do I align the gears so the shifter forks line up properly?
Thanks a lot for your help.
