Company Logo Shop Now
TractorLinks.com
Help with year
Rrh9wg
06-27-2020 12:58:21
I just bought an Allis Chalmers for the first time. This is my first time buying a tractor of any kind, so I am new to the tractor world. Any way, the tractor number is WC172302 and I was trying to find out what year it is so I know how to proceed in restoring it. I have it running and I already have her working the road and some of the field. But I don't know much about her so any help you can give would be much appreciated. Thanks
Rrh9wg
06-29-2020 04:38:49
 Re: Help with year in reply to Rrh9wg, 06-27-2020 12:58:21
[img:a466cf9b26][/img:a466cf9b26]
Rrh9wg
06-29-2020 04:27:58
Ok, this is probably going to sound dumb, what's "styled" and "unstyled" and how do I tell the difference?
Rrh9wg
06-27-2020 15:17:25
Thanks for the tip, I changed all the fluids and lubed what I could find but for some reason I never thought about picking up a parts manual. I was looking for the year so that I could get some of the other manuals. Thanks for the help, any other tips would be welcomed
4wdtom
06-28-2020 05:39:21
 Re: Help with year in reply to Rrh9wg, 06-27-2020 15:17:25
The year doesn't matter much even between "styled" and "unstyled" tractors. Mechanically WCs are all about the same. The parts manual is usually the most expensive but especially if you are new to the tractor or want to work on it it will be helpful.
4wdtom
06-27-2020 14:42:25
What you want to do if you haven't already is get a set of manuals, operator, repair, and maybe even parts. The parts manual is good for seeing how the parts all fit together even if you don't use it for the part nos. to order parts. Then at least inspect ALL the fluids, including the final drives, and lube all the lube points.
Rrh9wg
06-27-2020 14:20:31
Quoting Removed, click Modern View to see thank you
Jerry Coulter
06-27-2020 14:03:46
If you bring up "serial numbers" from the far left column, you will find that your tractor is a 1948 model, the final year of production.
Copyright © 1997-2020 Yesterday's Tractor Co.
