Company Logo (800) 853-2651 Shop Now
twisted alxe splines D 15
marlin54
06-22-2020 16:08:23
well I was wondering why the snap ring was off its slot and just hanging there and when I did get the parts out I see the spline was twisted and so it wont slide far enough to get room for the snap ring to go on. real close but not quite there . so im not sure how it came off or how long its been off or whoever worked on it earlier left it off. and so I also don't see how far axle bearing goes on ? It looks like it not on far enough and I don't see a stop for it or a ridge ? I think the bearings are both good and seal looks fair but I have it apart I am going to get new. . Is there a point when you press the new bearing on that it comes up against a ridge like other shafts so you know its where it is supposed to be ? even though its a 615 I believe the final is the same as the agriculture D 15. So I m looking for a axle and I imagine the right and left side is the same part # ?
4wdtom
06-23-2020 04:57:07
 Re: twisted alxe splines D 15 in reply to marlin54, 06-22-2020 16:08:23
Jim has it right, that's how it goes together and works. I might be looking for another axle. I don't think twisting them like that is common and possibly that one isn't right somehow, not as strong as it should be for some reason. You could file or grind the splines on the axle or gear enough to get it to go together with the snapring but it might twist more in the future and possibly twist off. You are right, the bearing in the picture looks good.
Jim.ME
06-22-2020 16:46:15
The outer bearing (in your picture) is against the shoulder as it should be. As for the inner bearing you do not " press the new bearing on that it comes up against a ridge like other shafts so you know its where it is supposed to be". Bearing preload determines where it needs to be. The inner bearing slides on the small end of the shaft allowing the preload on those two bearings to be adjusted with shims. The shims are located between end of the shaft and the heavy flat washer, which is held on the end of the shaft by a cap screw. This shimming for preload is described in assembly procedure in the manual for the D15s and other AC's using this type final drive set up.
From the parts books it appears the D14 and D15 used the same rear axle.
Today's Featured Article - Tractors and Winter - by Staff. Unfortunately, tractors and winter don't mix well. It seems that I can start out with my tractors in great running condition but sometime during the long cold dark winter they quickly revert to the lawn-art category. The lack of running, cold weather, and admitted neglect all take their toll on a machine. If you are lucky enough to not need your tractors during the winter months you can perform a few simple maintenance items to winterize and come spring have them going by reversing the process. If you need your tractor in ready-to-run condition (like that ... [Read Article]
Latest Ad: want to buy open station platform and fenders for 4430 john deere, needs to be in good condition . [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
