Well I believe the amount of play in my D15 rear axle is too much and I am trying to disassemble the parts to fix it. so it looks like someone else has already worked on it as I found some of the cap screws in the cover at bottom of the drive where new and then when I got that off I could see up in there the snap ring was not put back on it was just hanging there around the shaft and that lets the gear side around . so evidently some took it apart and could not get the snap ring back on . well I can say its looks really hard to see how it gets removed or put back on. there is just hardly any room to work with. Has anyone ever had to remove and put back ion this snap ring from looking up underneath the tractor. I cant be easy. laying on my back trying to get up in there is really tough. I would say if my tractor did not have the backhoe arms bolted to it and I could just pull the whole final drive of the trans it would probably be easier but I cant take it off without removing the backhoe. so I stuck working from the bottom looking trying to get the snap ring off and then I will have to put it back on again. is there a special snap ring pliers for this job? and I still have not got the shaft out yet as the manual says to put the cap screw back in the shaft and leave the shims out the take a hammer and drive the shaft out and if that does not work they have a threaded hole in the outer flange to use a puller on it. has anyone ever done this and got the shaft out without the puller by just driving it out from the other side ? and what is holding the shaft on other that the gear? the axle moves about 3/8 inch out then gets tight ?
