Company Logo Shop Now
AC c not starting
twheeler13
06-10-2020 18:59:08
Have a 49 C (possibly a C but canít read serial #) that quit after running good for several weeks after I obtained it. Rebuilt carb, replaced plugs, wires, distributor cap and rotor as well as coil (Had been converted to 12 volt). New battery but will not start -cranks strong but wonít start. Not sure what else to try. Appreciate advice!
funky_g00
06-10-2020 21:25:40
 Re: AC c not starting in reply to twheeler13, 06-10-2020 18:59:08
Check the basics, diagnose first, parts second. Do you have spark? Is it a hot blue spark and not yellow? Is there fuel in the tank? Water in the fuel? Good flow from bottom of carb to fill a pint jar in under 3 minutes. Check for power at the coil and distributor. Just as a guess, based on your description, your condenser went bad but PLEASE DIAGNOSE before changing that because half the time the new ones are bad out right out of the box.
twheeler13
06-11-2020 05:47:53
 Re: AC c not starting in reply to funky_g00, 06-10-2020 21:25:40
Thanks much! Will be out there to day and run through a diagnosis. Thanks again!
Latest Ad: john deere 700 a hood for industrial tractor rare [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
