dieselherb
Dr
Looks like I need to pull the radiator to allow room to pull engine. In which direction does the rad come out? Also I need to move the rad support like you said but 1 of the 3 bolts on each side will not come out, nut is off bolt won't budge. Is there a lot of weight on those bolts? Do I need to jack the housing up to get those bolts out?
Thanks[/b]
Thanks[/b]
