Allis C Hydraulic System operational design
Is the hydraulic system designed so when you push the clutch down should the implement drop? I have a belly mower on my C and that's what it does. I don't have any leaks and the little
hydraulic ram looks good. I would think you would want it to hold. Or is it out of adjustment?
You help would be much appreciated.
Regards
Dave
Can't say about a C, but I have a B and the hydraulics do not drop when my clutch is in. Basically a similar design just different wheel base.
(quoted from post at 22:50:43 05/19/20) No
Thanks Guys,
My belly mower drops down within a few seconds of clutch engagement or shutting off the tractor. Is there an external adjustment that I can make. I see it has a knurled know but I don't want to mess with it until I know if this where I would start.
Or would it be an internal issue that requires disassembly/repair?
Regards
Dave
