wd-45 update
bobs old iron
posted a few weeks about genny and battery, it's a 6v pos ground, fixed the cable [which had a 12v cable for the ground]starts good, now i have the genny wires disc because amp meter shows discharge, with two wires off genny is these the way they should be connected, and how do i make sure polairty is flowing rhe right way.
The "F" terminal on the gen goes to the legitimate OEM style light switch, which is a GROUND. The light switch has a low charge (pushed in) and high charge (pulled out). The instrument panel has a screw in the lower left corner. IT HAS TO BE THERE AND CLEAN CONNECTION FOR A GROUND OR THE GEN CANNOT CHARGE !!! You could have a bad light switch. You can ground the "F" terminal at the gen to make it charge max output to verify the systems condition. A good solid ground. Not a poor ground.
