Company Logo Shop Now
TractorLinks.com
wd-45 update
Bobs Old Iron
05-16-2020 19:38:22
posted a few weeks about genny and battery, it's a 6v pos ground, fixed the cable [which had a 12v cable for the ground]starts good, now i have the genny wires disc because amp meter shows discharge, with two wires off genny is these the way they should be connected, and how do i make sure polairty is flowing rhe right way.
Bobs Old Iron
05-17-2020 15:37:06
 Re: wd-45 update in reply to Bobs Old Iron, 05-16-2020 19:38:22
thanks, will check on screw and take a pic to show, don't knw if prev owners played with wireing
Traditional Farmer
05-17-2020 04:29:27
Also the box that houses the switch,amp meter etc needs to have the screw in it tight to make it charge.
DrAllis
05-16-2020 23:24:46
The "F" terminal on the gen goes to the legitimate OEM style light switch, which is a GROUND. The light switch has a low charge (pushed in) and high charge (pulled out). The instrument panel has a screw in the lower left corner. IT HAS TO BE THERE AND CLEAN CONNECTION FOR A GROUND OR THE GEN CANNOT CHARGE !!! You could have a bad light switch. You can ground the "F" terminal at the gen to make it charge max output to verify the systems condition. A good solid ground. Not a poor ground.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
