choke rod to carb.
jerry j
New User
Hello All, I"m new to this forum and need help with my WD, I removed the Carb. to replace it, I forgot to take a pic. of the Choke rod on the Carb. before I removed it and now I cannot get the choke rod to work the choke. I"m wondering if someone could poat a Pic. of how the rod connects to the Carb.?? Would Appreciate any and all help i can get. Thank You !!
While it was disconnected did the linkage where it goes under the gas tank get flipped around or out of position?
This might help.
I just reread your post.
Apparently you replaced the carb?
The choke levers on some non original carbs are different
than the original.
On some the lever is on the opposite side and on some,
the lever points up instead of down.
All carbs I've seen on WDs (both Marvel-Schebler and Zenith)
have the lever on the right (on the engine side) and they point down.
