Bigiron
I have my eye on a 7020 with power shift. I have no experience with AC tractors. Are these generally a good tractor and what should I pay attention to when I look at it? Thanks
They have a good reputation. I would check the usual things. Drive it and check for noises, leaks, etc. The power shift transmission is tough, if it has been serviced like it should. Some of these do have a rougher shift between 1st and 2nd gears, which is pretty common. Overall, a dependable tractor on pretty much the same chassis as the larger tractors.
