Allis Chalmers 5020 4WD parts needed
searlest
New User
Hello all and thanks in advance! I am new here and need a little advice.
I have a Allis Chalmers 5020 4 WD
supposedly same as
Massy Ferguson 210 , Simplicity 9523 and Hinomoto E23
I need replacement parts for the right front axel
Below are the names and Allis Chalmers part numbers of the parts I need
What is the availability of the parts ?
Does anyone know if the below part numbers are the same for the MF or Simplicity
Item
12) 2098756 qty 2 Seal Oil
15) 2098759 qty 2 Bearing
18) 2098762 qty 2 SEAL King Pin
19) 2098970 qty 2 Bearing thrust king pin
20) 2098764 qty 2 O-ring
27) 2098770 qty 2 Bearing
28) 2098771 qty 2 gear (13T)
29) 934008 qty 2 RING Snap
You might try Worley Tractor parts at 812-883-4313 and there is a place in Kentucky that deals in import tractors I think the name is Western Kentucky Tractor , I dont think you will find new parts for that tractor .back when I work for an Allis dealer parts for them were hard to get GOOD LUCK
I wonder if a bearing specialist might be able to cross reference the seals and bearings?
Fleck Bearing in OKC comes to mind but surely there are other indudtrial bearing suppliers in your neighborhood.
go to the Agco site to find part numbers. I an looking for steering parts for 210-4 MF. Massey uses 328xxxxM1 on most parts and different key munbers.
Just checked obsolete parts depot and they don't have any of the parts and also did a parts search on tractor house and no luck. There's 15 5020's listed on tractor house in the dismantled machines section, but none of them say if their a 4wd or not. But it may be worthwhile to call them and see if you can get the gears. hope this helps.
