My wife was box scrapping the sheep feed lot and she said the clutch squealed for 5 seconds and then the pedal dropped. The tractor stayed in gear and needed to be shut off to stop. I opened up the
bell housing access hole and you can see that the fork slipped off of the throwout bearing. There are 4 tabs on the throwout bearing that hold it in place with the fork. I released the clutch lever from the
pedal and I could tap the throwout bearing around enough to get the fork to go back between the 4 tabs. I thought maybe it just slipped loose and needed to be relocated. Nope. Fell right off again. Back
to square 1. I split this tractor 3 years ago, replaced the clutch, pressure plate, and bearing. This problem just showed up today. What am I missing?
