I have an Allis-Chalmers HD7G crawler loader. Ran and operated great last fall. Then parked for the wet winter.
Runs and operates as should for about 2-5 minutes.
Then loses all transmission hydraulic pressure/transmission lube pressure. Then after sitting for about 30 minutes, will run and operate fine for another 5 minutes, before sitting still. Engine Runs perfectly, Bucket and arm pistons work great. Just won't move forward/reverse or turn.
Last spring when I bought it, I went through all the rotten hoses, all the filters, and screens, and did a full oil change on the transmission, and engine.
I dont believe its a torque converter issue because I think the torque converter picks up and provides pressure for the bucket hydraulics which are working fine.
There is a return screen that I can check, but that requires draining 24 gallons of transmission/wet brake oil (not 303), I've already replaced 2 out of the 3 hydraulic filters today. The screen is the lowest thing on the machine, the filters are the highest.
Anyone an old heavy equipment mechanic with some wisdom that might save me a $400 oil change with something they remember on these machines?
No oil leaks that I can see, Fluid at top level, starts out full pressure on gauges, and acts like its getting vapor locked or the fluid isn't returning to the sump after 3 minutes or so. If i let it sit five mins it wont do anything, 30 or more is required.
