3 Bottom Plows
I have a 3 16" 70 series I believe, and a 3 14'' 50 or 60 series with the rear tail wheel. I want to put the tail wheel on the 3 16 newer plow. The holes match up. Other than looks is there any advantage to me putting the tail wheel on a swap? Also, What is the tire size of the tail wheel. I attached a picture. Thoughts?
Should be no problem to add the tail wheel. The tire is a 4x9.00 if i remember correctly. It is a two piece rim that you separate
to install a new tire/tube. Y0u will need to swap the beaming screw setup from one to the other also. As far as plow series: The
two are either 60 or 70 series from the picture. The two looked the same except the 70 series had an adjustable width frame (set
for 14 or 16) and the 60 series is fixed.
