KCTractors
- Location
- Central Wi
Just bought this tractor and had this problem from the get-go. If I try to start the tractor with-out plugging the heater in. The starter will keep turning the engine over. I have to take a battery cable off to stop the starter. The starter will not turn over if I don't the clutch pedal down but when I release the starter button on the dash and let the clutch out on the dash, the starter continues to keep turning over.
I replaced the starter solenoid and the starter button on the dash and it does the same thing.
When I plug the block heater in the tractor, the starter works just fine. Any suggestions to what the problem is. This on a AC 170 Diesel.
