I have a 47 Allis Chalmers B that is stuck in 3rd gear. Can I go through gearshift and unjam or will I have to take the transmission control cover with shifting forks off to do this. This happened while rocking tractor to turn flywheel off bad teeth (have new ringgear ordered). A related question is about starter. This tractor has been simi-converted to 12 v (no alternator). The starter apparently was changed because is has a solenoid start. It doesn't appear that the bendix teeth are engaging fully, causing the outside of the ring gear to strip. The starter doesn't mount flush with housing, leaving about a 1/4 gap between starter and housing. Starter is a Delco 110747. I have a 42 AC C with button start I am working on and I can't tell any difference in starter lengths.
