Pedestal Front end
bwillett
What is the best, easiest, safest way to separate the gear assembly and the spindle block from the shaft on my 1936 WC???? I need to replace the lower seal, and the gear on the top.
Thanks in advance.
https://na.apb.agcocorp.com/p/agcoallis/79001545/l/129? I'm going to guess a large puller of some kind on the worm gear. Might be able to just drive the shaft down out of the gear too, but I doubt it with that woodruff key in there.
AaronSEIA
