ALLIS WD45 Diesel Frame
You would be correct. I didn't check both part numbers. The right side frame rails are the same. My original answer was half right. They are the same length.
AaronSEIA
Left frame has the top mashed down under the injection pump so it can clear. Length is the same as a gasser.
