Allis B sickle mower
grandpa Love
Guy sold this to me. He took it off a
Farmall A. Folks on farmall forum say
it's Allis. What say the Allis guys?
Agreed, it is for a B/C and the rear frame rails have been cut. They are supposed to extend back and mount on the drawbar. If you find an uncut mower you could measure how much has been cut off and weld on some extensions. Also the front uprights look like they have been modified too as the bolt holes at the top don't look like they would fit the B/C bellhousing. If fitting it to a B/C you need to have the pulleys lined up. There are two sized pto shafts too, 1 1/8" on earlier tractors and 1 3/8" on later ones. I believe the single groove pulleys on the earlier ones were larger diameter than the double groove pulleys on the later ones.
I don't think it is going to be too difficult to "re-adapt" that to a B.
Once you set it under the tractor, you can easily determine what pieces have to be welded on to make it work.
Back in the late 40s my Dad, with the help of a professional welder,
converted a horse drawn JD mower to fit under the belly of his B.
That was a little more difficult
